Contacts not sorting in "File As" sort order
Beans1
For some reason my contacts have started sorting themselves in " First, Last name" order instead of " Last, First name" as they have previously been sorted. I have checked a few contacts and the " File as" field is showing correctly. The sort order is definitely set to " File as - ascending" .
I am using Outlook 2007 on Windows 7 Home premium.
If I change the file as filed for a contact to first, last, save and change back to last first, it seem to recognise the new order. This could be painful for several hundred contacts.
I have just synced Outlook to a new HTC Desire smart phone. not sure if this caused it. Also, yesterday Outlook did not shut down and I had to force it to end, seemed to re-open OK.
It seems like the indexing file may be corrupt, can this file be deleted and forced to regenerate?
Any suggestions will be appreciated.
Beans1
Thanks Russ, The code under the link seems to have worked.
Beans
Russ Valentine
Good to know. Thanks for the follow up.Russ Valentine
