problem when importing contact data from one computer to another using .pst file
  • Thread starter jriles
  • Start date Views 634
jriles
Only partial data associated with a conact is imported from a .pst file. I have created a .pst file from my 2003 outlook program on laptop #1 (running window XP) and imported it into laptop #2 outlook 2003 program (running windows 7). For some conacts (not all) I cannot view all the associated contact data includng activities, tasks and note. I have tried more than once creating seperate .pst files thinking a files may have been damaged but the same thing happens. Any help/ suggestions would be greatly appreciated.
Russ Valentine
This is one of the many reasons you will find countless posts here that tell you importing is not the correct way to transfer Outlook data. You will always lose this information when you import. We have also posted here countless times the correct way to transfer Outlook data. Copy the Outlook data file and open it. Search the forum if you need more details.Russ Valentine
