outlook keeps saying not responding and then hanging
G
Guruprasad Ra
If Outlook safe works as expected, disable the add-ins for the Outlook using the following steps:.
a) Click on File menu, click Options > Add-ins > Go button besides Manage: Com-in Add.
b) Check if there are add-ins listed, clear the checkbox to disable them.
c) Close the Office program and restart it.
d) Disable each add-in one at a time, restart the Outlook, and repeat the above procedure. If the issue reappears again, it will help you to determine which add-in is causing this issue.
