Re: Cuestom outlook rule using vba
  • Thread starter Ken Slovak - [MVP - Outlook]
  • Start date
K
It looks like there aren't any conditions that meet what you want in the
Rules collection, so a rule that runs a script is your best bet.
"mherber2" <mherber2.3f756cd@outlookbanter.com> wrote in message
news:mherber2.3f756cd@outlookbanter.com...
> i am using 2007 however there is not a built in rule to sort when a
> message is sent to someone in a specified address book
thats not a problem can you assist me in writing the script?
' - [MVP - Outlook Wrote:
> ;295682']It looks like there aren't any conditions that meet what you
> want in the
> "mherber2" mherber2.3f756cd@outlookbanter.com wrote in message
> news:mherber2.3f756cd@outlookbanter.com...-
> message is sent to someone in a specified address book-
mherber2
Start coding it and post any problems or questions and someone will help.
"mherber2" <mherber2.3fb4b51@outlookbanter.com> wrote in message
news:mherber2.3fb4b51@outlookbanter.com...
i have experiance in vba for excell and power point but i have no clue
where to begin here. i've been working on coding it but cannt get
anywhere
> ;295859']Start coding it and post any problems or questions and someone
> will help.
> "mherber2" mherber2.3fb4b51@outlookbanter.com wrote in message
> news:mherber2.3fb4b51@outlookbanter.com...-
> thats not a problem can you assist me in writing the script?-
mherber2
Well, the rule calling the macro "script" is passed a Mailitem object for
the item. To check for Subject containing a specific word:
Sub myRuleCode(Item As Outlook.MailItem)
If InStr(1, Item.Subject, "foobar", vbTextCompare) > 0 Then
' it has the subject word "foobar" there
To check for the recipient being in a specific AddressBook you'd need to get
the Item.Recipients collection and iterate, checking each Recipient for
their email address and seeing if the Recipient.Type = olTo (if you only
want to check the To recipient or recipients).
The AddressBook would be retrieved from the AddressLists collection as an
AddressList object. You'd get its AddressEntries collection and iterate that
looking for an AddressEntry where the Address property was equal to the
Recipient.Address.
To check for the sender being in the AddressEntries collection you'd use the
Item.SenderEmailAddress property and compare that to each
AddressEntry.Address value in that AddressBook.
If you know the name of the AddressBook you want to work with you'd get it
like this:
Dim oList As Outlook.AddressList
Set oList =
Application.GetNameSpace("MAPI").AddressLists.Item("myAddressList")
That should get you going.
"mherber2" <mherber2.3fc9cd5@outlookbanter.com> wrote in message
news:mherber2.3fc9cd5@outlookbanter.com...
> anywhere
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 9
J Outlook VBA to send from Non-default Account & Data Files Outlook VBA and Custom Forms 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Outlook is categorizing emails incorrectly Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
A Outlook can't remember outlook.com, Exchange password. Using Outlook 6
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 8
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
A Outlook 2019 folder counter Using Outlook 0
A Relocate Search Bar in Outlook Using Outlook 2
L Opening People Outlook 2021 Using Outlook 2
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
