1. Here's a thread that needs an answer: Contact Synchronization - Outlook to Outlook.com
incoming messages plain text font/appearance
Discussion in 'Using Outlook' started by 11VJC11, Nov 1, 2010.
  1. 11VJC11
    11VJC11
    Guest
    How do I change the text/font and size for incoming plain text messages in Outlook 2007?
  2. Russ Valentine
    Russ Valentine
    Guest
    Note that the appearance of incoming messages is set by the sender and cannot always be overridden by Outlook. If they can, you would do so in Tools > Options > Mail Format > Stationery and Fonts... > Composing and Reading Plain text messagesRuss Valentine
  3. 11VJC11
    11VJC11
    Guest
    I am aware that sender determines appearance. However, for the past 4 years all plain text messages came in as Verdana 12pt which is what my settings are in Tools > Options > Mail Format > Stationery and Fonts... > Composing and Reading Plain text messages. Suddenly they began coming in as Times New Roman 10pt alhought my settings haven't been altered.
  4. Russ Valentine
    Russ Valentine
    Guest
    So I assume you know of nothing that changed just before "suddenly." As I said, this feature will not work consistently because too many variables affect whether Outlook will detect a message as plain text at the time it hits the local Inbox. It's always worth resetting the format to something else, restarting Outlook, then setting it back to your preference just to make sure your setting preferences didn't get corrupted.Russ Valentine
Loading...
Share This Page
