List Click
V
VEdhbGlu
I want to put the contents of A1:N100 from an Excel Worksheet into a new
email. However I want set up the new email so that the contents of A1:N100
can be minimized or maximized with a click. In other words with one click by
the recipient or me I would like only one row to be displayed and with one
more click the entire range A1:N100 to be displayed. Can you help me?
That's not possible.
Sue Mosher
"TGalin" <TGalin> wrote in message
news:2AC4A717-B8B8-4F63-A7AD-4AA4A2F4BED4@microsoft.com...
> A1:N100
> by
farrissf Category list to pick from Outlook VBA and Custom Forms 4
S Inconsistent view of To-Do List Using Outlook 0
S Different views for To-Do List and To-Do Bar Using Outlook 1
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
K Daily Task List Minimized Cannot Display Using Outlook 5
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
Ken Pascoe Outlook Categories Quick List Using Outlook 0
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 5
C must select message to trigger safe list Using Outlook 3
V Pin a document to the "Attach file" Recent Documents list Using Outlook 0
Witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
C Why won't Title display in message list? Using Outlook 1
T Increasing the number of items that appear on the Categories list Using Outlook 2
Z How to show concatenated categories in list task view? Using Outlook 2
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
B Outlook 365 - Folder pane list clears Using Outlook 28
B All imported tasks appear in to-do list Using Outlook 3
B Outlook - Mail from safe senders list being sent to Spam Folder Using Outlook 0
M Message list font changed after update Using Outlook 2
A Order of Recent Items in Attach File List Using Outlook 5
O Address list - company and non-company ? Using Outlook 0
M Daily Task List Minimized Cannot Display Using Outlook 2
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
Jennifer Murphy To Do List Views Using Outlook 0
