Outlook 2007 Error - Freezing upon start-up, extend.dat error.
  • Thread starter JOR2010
  • Start date Views 1,497
JOR2010
#1
I have had Outlook 2007 installed for a few years, has been working fine all the time. I go back in today, just a few hours after it was all fine, and it tells me about an error involving extend.dat. I follow internet forums who tell me to rename it to extend.old, but it does nothing. I also run outlook.exe /resetnavpane, but it has the same effect, and does not help.
Every time I now enter Outlook, it freezes very quickly and does not respond almost straight away - before it was instantaneous.
Regards
JOR2010
P
Palcouk
#2
You are using an OL data file created by 2007 or 2003 versions?
Running scanpst.exe does it find / correct err's in the data file?
And if you start OL using the safe switch, how does it behave?
Finally have you run a HD check?
V
Vinay - G
#3
Did you try working in Outlook safe?
Try the following steps:
Click on Start > All Programs > Accessories > Run > Copy and Paste the following command in the open box and press Enter.
Outlook /safe
1. If Outlook safe works as expected, disable the add-ins for it using the following steps:
2. Click on File menu, click Options > Add-ins > Go button besides Manage: Com-in Add.
3. Check if there are add-ins listed, clear the checkbox to disable them.
4. Close the Office program and restart it.
5. Disable each add-in one at a time, restart the Outlook, and repeat the above procedure. If the issue reappears again, it will help you to determine which add-in is causing this issue.
