Outlook 2003 alert problem
H
Henry
How can I turn Outlook alerts off?
When I try to send an email from my Excel VBA program I get the following
alert.
"A program is trying to automatically send e-mail on your behalf. Do you
want to allow this?"
Yes, No or Cancel.
Is there a way to either turn off the alert or automatically answer Yes.
Relevent part of program:
-------------Set appOL = CreateObject("Outlook.Application")
Set appMess = appOL.CreateItem(olMailItem)
For cnt = 1 To 99
If ISLIKE(Cells(cnt, 12).Value, "*@*") Then 'does cell contain email
address?
appMess.To = "Valid.e-mail@address"
appMess.Subject = "tester"
appMess.Body = "test"
appMess.Send <------ this causes alert to show
Next cnt
appMess.Quit
appOL.Quit
Set appOL = Nothing
Set appMess = Nothing
Henry
See http://www.outlookcode.com/article.aspx?ID=52 for your options with
regard to the "object model guard" security.
Sue Mosher
"Henry" <henry.best@no_way.com> wrote in message
news:jCkJl.80591$vI1.16253@newsfe14.ams2...
> alert.
> Yes, No or Cancel.
> -------------------------------------------> Set appOL = CreateObject("Outlook.Application")
> For cnt = 1 To 99
> email address?
> End If
> Next cnt
> appMess.Quit
> appOL.Quit
> Set appOL = Nothing
> Henry
Thanks Sue.
> with regard to the "object model guard" security.
> > following alert.
> > you want to allow this?"
> > Yes, No or Cancel.
> > Yes. Relevent part of program:
> > -------------------------------------------> > Set appOL = CreateObject("Outlook.Application")
>> For cnt = 1 To 99
> > email address?
>> End If
> > Next cnt
>> appMess.Quit
> > appOL.Quit
> > Set appOL = Nothing
>> Henry
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
