Error starting MS Outlook - Problem Event Name CLR20R3
  • Thread starter Sydney Taylor
  • Start date Views 10,857
Sydney Taylor
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: outlook.exe
Problem Signature 02: 14.0.4760.1000
Problem Signature 03: 4ba8fefd
Problem Signature 04: Mainsoft.Harmony.AddIn
Problem Signature 05: 1.2.0.8836
Problem Signature 06: 4c90f159
Problem Signature 07: 137
Problem Signature 08: f
Problem Signature 09: System.InvalidCastException
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Does outlook start in safe mode or if you disable the " Mainsoft.Harmony.AddIn" addin?
To start in safe mode: Close Outlook. Hold Ctrl as you click on the Outlook icon to open in safe mode.
To disable addins: File, Options, Addins. Click Go at the bottom of the page and uncheck the addin - it will probably be listed with a 'friendly name' so you'll need to figure out which one it is.
