Error while running setup /preparead
  • Thread starter FuriousAngelPT
  • Start date Views 1,550
F
FuriousAngelPT
While installing the exchange 2010 when it get to tha part /preparead it gives an error something missing in AD
windows 2008 std One DC, and exchange being installed on this server.
Thanks for the help.
[10-24-2010 15:47:21.0679] [2] About to create the dob for object /dc=local/dc=MARSOSA/cn=Configuration/cn=Schema/cn=ms-Exch-Schema-Version-Pt
[10-24-2010 15:47:21.0679] [2] The schema version identified for the Server is 14726
[10-24-2010 15:47:21.0679] [2] Leaving ScGetSchemaVersion
[10-24-2010 15:47:21.0679] [2] Leaving CDirectoryManager::ScSchemaIsUpToDate
[10-24-2010 15:47:21.0679] [2] Entering CDirectoryManager::ScGetCountOfOrgsInDomain
[10-24-2010 15:47:21.0679] [2] CDirectoryManager::ScGetCountOfOrgsInDomain (f:\14.00.0639\sources\dev\admin\src\udog\setupbase\tools\dsmgr.cxx:493)
Error code 0X8007200A (8202): The specified directory service attribute or value does not exist.
[10-24-2010 15:47:21.0679] [2] Leaving CDirectoryManager::ScGetCountOfOrgsInDomain
[10-24-2010 15:47:21.0679] [2] CDirectoryManager::ScGetOrgLevelObjectStatus (f:\14.00.0639\sources\dev\admin\src\udog\setupbase\tools\dsmgr.cxx:536)
[10-24-2010 15:47:21.0679] [2] Leaving CDirectoryManager::ScGetOrgLevelObjectStatus
[10-24-2010 15:47:21.0679] [2] CDirectoryManager::ScReInitWithDC (f:\14.00.0639\sources\dev\admin\src\udog\setupbase\tools\dsmgr.cxx:267)
[10-24-2010 15:47:21.0679] [2] Leaving CDirectoryManager::ScReInitWithDC
[10-24-2010 15:47:21.0679] [2] ScInitializeManagedCodeContext (f:\14.00.0639\sources\dev\admin\src\udog\exsetdata\exsetds.cxx:380)
[10-24-2010 15:47:21.0679] [2] ScSetupAtom (f:\14.00.0639\sources\dev\admin\src\udog\exsetdata\exsetds.cxx:881)
[10-24-2010 15:47:21.0679] [2] Leaving ScSetupAtom
[10-24-2010 15:47:21.0694] [2] [ERROR] An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exist.'.
[10-24-2010 15:47:21.0694] [1] The following 1 error(s) occurred during task execution:
[10-24-2010 15:47:21.0694] [1] 0. ErrorRecord: An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exist.'.
[10-24-2010 15:47:21.0694] [1] 0. ErrorRecord: Microsoft.Exchange.Management.Deployment.ExsetdataException: An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exist.'.
[10-24-2010 15:47:21.0694] [1] [ERROR] The following error was generated when " $error.Clear(); install-ExsetDataAtom -AtomName OrgLevelCt -DomainController $RoleDomainController -Organization $RoleOrganizationName" was run: " An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exist.'." .
[10-24-2010 15:47:21.0694] [1] [ERROR] An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exist.'.
F
FuriousAngelPT
yes
the schema from the exchange installation is older then the one in AD. tried /ps from sp1 and it worked.
