Problems with showing information(meetings) in shared calendars..
Skoude
Hi!
We have problems when viewing the shared calendars. When I make a new meeting and add a resource to it.. Then I send a meeting and I get a response from resource that it is accepted. Sometimes it shows the meeting straight avay in resources calendar and sometimes it takes multiple restarts of outlook and still it might take several hours..
So does anybody have any idea how to solve this problem?
C
Christian Weihs
Hi Skoude,
Hi!
Which Clients you are using? Compared to Outlook 2007 and later, which will
directly check the mailbox, Outlook 2003 have a look to the public folder.
The informations in the public folder will be updated by Outlook every 15
minutes:
http://msexchangeteam.com/archive/2006/10/23/429296.aspx
Best regards
Christian
C
Christian Weihs
Hi Skoude,
Hi!
We are using outlook 2010!
Same issues in OWA or could you see the informations there in time?
Any error message at the exhange server when you recognize the delay?
Best regards
Christian
G
Gen Lin
Try to uncheck the shared calendar and then recheck it. What's result?
Skoude
Hi!
Sometimes this unchecking an checkin works and sometimes not.. I haven't found anything from the logs, but there could be something.. Maybe I haven't checked from right place ..
Haven't tested this on OWA. I will take a look at it and put the results here..
