how to print all emails sent and received via edge in 2010
Suhail.Pir
hi all.
please if someone can help me how to get list of all email messages sent and received via edge server. i m using 2010. manually without using any other tool. using edge own features.
waiting
thanking u in advance.
Regards
SHAH
Suhail.Pir
thanks and done!!
can i get mails result for a specific period of time i.e. from this date to that... how can i print the result?
once again thank u Frank.
Suhail.Pir
i mean to print result for all users not a single one.
Get-MessageTrackingLog -Start " 03/13/2010 9:00AM" -End " 03/15/2010 5:00PM" -Sender " john@contoso.com"
F
Frank.Wang
Hi SHAH,
So just run the Get-MessageTrackingLog -Start " 03/13/2010 9:00AM" -End " 03/15/2010 5:00PM" , don't specify the -sender parameter...
Suhail.Pir
hi Frank!! sorry for bothering U again :)What if I were to want to filter the messagetrackinglog to only look at, say, distribution groups, and I only wanted to show a message count? I've gotten good results on a single recipient with | measure-object, but I'd like to get a message count for each DL.
F
Frank.Wang
Hi Digital.Drop,
If you want to filter the logs, you can use the Where syntax.
For example:
Get-MessageTrackingLog -Start " 03/13/2010 9:00AM" -End " 03/15/2010 5:00PM" | where {$_.recipients -eq DGname@contoso.com}
Suhail.Pir
Get-MessageTrackingLog -Start " 03/13/2010 9:00AM" -End " 03/15/2010 5:00PM" | where {$_.recipients -eq DGname@contoso.com }
thats what i needed.
Regards Shah
Suhail.Pir
Get-MessageTrackingLog -Start " 03/13/2010 9:00AM" -End " 03/15/2010 5:00PM" | export-csv C:\result.csv
This will create a CSV file of the message tracking results with column headers that can then be imported into Excel.
final answer :)
Regards Shah
Suhail.Pir
also you can use this to retrieve all HT servers from your organization:
Get-ExchangeServer | where {$_.IsHubTransportServer -eq " true" }
Pipe this output (you can sort this output) to the get-messagetrackinglog and you get this:
Get-ExchangeServer | where {$_.IsHubTransportServer -eq " true" } | sort-object Name | get-messagetrackinglog -Sender:<<somebody>> -EventID " RECEIVE" -Start " 12/1/2008 2:04:00 PM" -End " 12/30/2008 2:14:00 PM" | convertto-HTML TimeStamp,ServerHostName,Sender,{$_.recipients},MessageSubject| out-file M_Tracks.htmlRegards Shah
