VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp
Michael Schmitz
Hello NG,
I am new to VSTO and Outlook 2007 Addins,
Well what i am trying, is to use a Outlook 2007-Add-In with
> .Net Framework 2.0.
When i switch in my "Hello world" example the Framework version from 3.5 to
2.0 and remove all
linq related stuff i get this error aftercompiling:
'MSB3185: EntryPoint not specified for manifest.'
http://msdn.microsoft.com/de-de/library/ms228185.aspx
Is it not possible to switch this project to 2.0 Framework?
If it is possible, what do i have to do?
Regards
Michael
I hate to redirect you again, but you should post this in the VSTO forum at
http://social.msdn.microsoft.com/forums/en-US/vsto/threads/ where you're
more likely to get an answer.
"Michael Schmitz" <spam@gmx.net> wrote in message
news:OuMgrYrwJHA.5672@TK2MSFTNGP06.phx.gbl...
> Hello NG,
> .Net Framework 2.0.
> to
> 2.0 and remove all
> Regards
> Michael
M c# vsto Outlook.ApplicationEvents_11_NewMailEx Outlook VBA and Custom Forms 1
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
O VSTO - Outlook Add-In - Get GAL data Outlook VBA and Custom Forms 1
M VSTO deployment? Outlook VBA and Custom Forms 1
K Outlook VSTO Add-in not visible in Trust Center after installing Outlook VBA and Custom Forms 1
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
S VSTO calling unmanged function Outlook VBA and Custom Forms 3
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
G Interop or VSTO or ? Outlook VBA and Custom Forms 2
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
O Outlook VSTO 2005 plug-in installer: CLSID = ? Outlook VBA and Custom Forms 3
O using VSTO to get Available Mailboxes Outlook VBA and Custom Forms 11
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
N How to add Dear & mail receipts name while reply to that mail in outlook2007 Outlook VBA and Custom Forms 1
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
D Outlook2007 Email problem with automation Outlook VBA and Custom Forms 4
Z Outlctl disabled (Outlook2007 SP2) Outlook VBA and Custom Forms 2
R Could i do this with ribbon(outlook2007)? Outlook VBA and Custom Forms 1
R About repurpose ribbonX of outlook2007? Outlook VBA and Custom Forms 3
Y How to record macros in Outlook2007? Outlook VBA and Custom Forms 1
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
Diane Poremsky Always Load an Outlook Addin Using Outlook 1
D Constant Dropbox Outlook Addin Authentication Prompts Using Outlook 5
T client addin deletes all business contacts BCM (Business Contact Manager) 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
M Icloud Addin in Outlook 2013 Exchange Server Administration 9
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
P Addin / macro / rule to highlight email addresses outside company in To: field Using Outlook 3
H Outlook 2010 Antispam Addin Not Available Using Outlook 1
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
G Addin to define message format on a per-contact basis? Outlook VBA and Custom Forms 1
C Connecting to an addin in Outlook 2010 (or not) Outlook VBA and Custom Forms 1
V how to collect details from user, during installation of office addin? Outlook VBA and Custom Forms 1
A how to enable macro for addin Outlook VBA and Custom Forms 3
