cannot connect with more then 5 current users to outlook anywhere exchange 2007
  • Thread starter Martijn Verhulst
  • Start date Views 551
Martijn Verhulst
I've installed SBS 2008.
I installed outlook anywhere, which works fine for 5 current users.
When the 6th user want to use outlook through outlook anywhere they can't connect. If one of the 5 currenct users closes outlook he can connect.
How can I fix this, I have about 10 users who need to use outlook anywhere.
OWA works fine, Everyone can login.
The clients have XPSP3/Vista with Outlook 2007
I have exchange 2007 SP2
Ripu Daman
I think there is some problem with config since outlook anywhere is not for 5 users only, try recheck the config have a look into these posts : http://social.technet.microsoft.com/Forums/en-US/exchangesvrclients/thread/4542230b-bd6f-41e0-b431-adecc28c9598
First, please try the online testing tool to narrow down the cause of the issue:
https://www.testexchangeconnectivity.com
For auto-discovery
Then paste the log of the result on the forum.
Additionally, the instruction for how to make Outlook Anywhere work as below link:
http://technet.microsoft.com/en-us/library/cc794265(WS.10).aspx
Also disable IP V 6, do let us know if this doesn't help or more info is required.
Ripu Daman Mina | MCSE 2003 & MCSA Messaging
ManU PhiliP [MVP]
As per my knowledge, there is no such setting for Exchange servers.
The thing you have to chek is
1. IIS Server: The number of simultaneous connections to the web site that the OWA directories(exchange, public, exchweb) may be limited there.
2. ISA Server: Check there for any such rules for incoming connections
Regards from www.windowsadmin.info
K
Khoj Sahiwala
Increasing Disgnostic logging for outlook anywhere would also be helpful
