Starting out and would like advice
C
cidr
Hi folks,
This will be my first post so hi.
I've been asked to design a Laptop pool form for the company. The form
should be able to record who in the company has a laptop and for how
long.
I imagine this is quite strait forward. the form should have a couple
of drop downs and a couple of text boxes to save the persons details.
Then, when they save the info, it should enter into that day of a
Calendar.
If the entry is clicked, i'd like a form to pop up with the details of
that person and who made the booking of that lap top etc.
That's it. There's not a great deal of info that I can find on the
Net. I was hoping I could get help; perhaps someone knows of articles
or books that will help me with my specific design?
Hope someone can help and thanks in advance.
Cheers
cidr
Start by looking at the Forms information and samples at www.outlookcode.com
"cidr" <cidr.40fba8f@outlookbanter.com> wrote in message
news:cidr.40fba8f@outlookbanter.com...
> Hi folks,
> long.
> Calendar.
> Cheers
> > cidr
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
N Starting out with BCM - Customizing contact records BCM (Business Contact Manager) 1
B Starting up outlook in Windows 8 Using Outlook 2
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
V Starting Fresh with a new PST file. Using Outlook 0
D Starting Outlook 2K3 without e-mail support Using Outlook 4
S Starting outlook in imap Inbox Using Outlook 7
C starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering' Using Outlook 3
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
J Want to 'modernise'(?) my email setup using Outlook. Any advice? Using Outlook 0
Horsepower Upgrade advice needed Using Outlook 3
K Master Category List / Contacts Public Folder Advice Using Outlook 4
C Advice on custom filtering Outlook VBA and Custom Forms 2
Q Need advice for correct event Outlook VBA and Custom Forms 1
