How can I send task request using vCalender/VTodo component using C#
I am writing a separate application to send task requests to the client using simple mail. Then the emails should be added to the mail box task list box in MS Outlook.
Here I have used vCalender/vTodo format to set values . But when I send the email it is not sending as a task request and it displays as an email but it is not added to the task list box. That is the question I have.
1. My Outlook version -2007.
2. language - C#.net
3. An Outlook add-in or Outlook automatic application?
Not a Add-in. A separate application there should not be a reference to the Outlook.
4. Visual Studio version - VS 2008
This is what I did.
public string CreateVTODO(DateTime start, DateTime end, String body, String sub, String status)
//Here I am not using parameters in method body.
StringBuilder sbvCalender2 = new StringBuilder();
sbvCalender2.Append("METHOD: REQUEST");
sbvCalender2.Append("\n");
sbvCalender2.Append("BEGIN:VCALENDAR");
sbvCalender2.Append("PRODID:-//ABC Corporation//NONSGML My Product//EN");
sbvCalender2.Append("BEGIN:TODO");
sbvCalender2.Append("20110502T134500Z");
sbvCalender2.Append("SEQUENCE:2");
sbvCalender2.Append("UID:manula.m@eyepax.com");
sbvCalender2.Append("ORGANIZER:MAILTO:derick.k@eyepax.com");
sbvCalender2.Append("\n"); sbvCalender2.Append("ATTENDEE;PARTSTAT=ACCEPTED:MAILTO:derick.k@eyepax.com");
sbvCalender2.Append("DUE:20110502T134500Z");
sbvCalender2.Append("STATUS:NEEDS-ACTION");
sbvCalender2.Append("SUMMARY:Kolkata Kinght Riders");
sbvCalender2.Append("END:VTODO");
sbvCalender2.Append("END:VCALENDAR");
return sbvCalender2.ToString();
public void SendmsgVTODO(DateTime start, DateTime end, String body, String sub, String status)
MailMessage mail = new MailMessage();
SmtpClient client = new SmtpClient();
//Set the date and time
DateTime startDate = start;
DateTime endDate = end;
//Location where you want to save the vCalendar file
string attachUrl = @"E:\SaveVCalenderFile\Test.vcs";
//Create task
using (StreamWriter sw = new StreamWriter(attachUrl))
sw.Write(CreateVTODO(startDate, endDate, body, sub, status));
//Attach the task
Attachment mailAttachment = new Attachment(attachUrl);
mail.Attachments.Add(mailAttachment);
MailAddress fromAdd = new MailAddress("sandun.k@eyepax.com");
mail.To.Add("manula.m@eyepax.com");
mail.From = fromAdd;
mail.Subject = "Test New Dk";
mail.Body = sbvCalender2.ToString();
mail.BodyEncoding = System.Text.Encoding.UTF8;
mail.IsBodyHtml = true;
client.Host = "smtp.gmail.com";
client.Port = 587;
client.UseDefaultCredentials = true;
client.Credentials = new NetworkCredential("eyepaxtest@gmail.com", "eyepax563");
client.Send(mail);
mailAttachment.Dispose();
Please help me.
Regards,
Manula
Thank you very much for your information. I am really confused coz of this problem and solution is not found yet. Hope your information will help a lot.
Regards,
Manula
M How can I send a Task Request using vCalender/vTodo format using C# Using Outlook 3
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send a Task Status Report Using Outlook 0
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
M Send email on task creation? Using Outlook 2
A Send Email to Task while sending to Email address Outlook VBA and Custom Forms 1
K send email when task changes Outlook VBA and Custom Forms 3
J Outlook VBA to send from Non-default Account & Data Files Outlook VBA and Custom Forms 3
C Synchronization and taking forever to send Using Outlook 2
T Outlook 2010 recipient no longer shows in 'Send To' Using Outlook 0
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
Geldner Send / Receive a particular group via macro or single keypress Using Outlook 1
M Outlook 365 refuses to send email Using Outlook 0
