Text fonts changing when exchange syncs
T1000
Example:
I set up a task in outlook on my PC.
In the area where you can type in the task details etc I highlight certain important sections of text (using bold, underline, capital, even change text colour to red)
The task will sync with my exchange so it will appear on my iPhone.
If I modify the task on my iPhone it will sync via exchange and update on my PC outlook.
The trouble is if I do make a change using iPhone, the next time I open the task in outlook PC the change has been synced OK but all the text font has been changed to a different font (i.e all the bold underlined text etc is just the same as rest of the text)
Any ideas how to stop this ?
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J Outlook 365 Emails showing as links and text only Using Outlook 4
J Text icon in Quick Access toolbar ? Using Outlook 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
W Message Text Using Outlook 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
