Quick Parts - Changing Display and Order
srmsrm
Outlook 365 64 bit
In Outlook 2003, I used Macros in Contacts and Signatures in Emails for repetitive text that I use. I'm starting to use Quick Parts in 2010 instead of macros and also signatures work differently in that you can only use one signature per email. It seems when you use a second signature, the first signature is replaced. If I'm incorrect, please let me know.
I have about 30 macros and around 50 signatures that I use. With Quick Parts, it shows quite a bit of text in the list to pick from. Is there a way just to show the Quick Parts name and also reorder them?
Shawn
M font format discrepancies with Quick Parts Using Outlook 1
C Quick Parts signatures suddenly require more letters Using Outlook 2
B Push Quick Parts to All Users Using Outlook 1
D Quick Parts - font changes Using Outlook 6
D Quick Parts - font changes Using Outlook 0
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
A Quick Access Toolbar Not Showing Description Using Outlook 0
J Text icon in Quick Access toolbar ? Using Outlook 2
Ken Pascoe Outlook Categories Quick List Using Outlook 0
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? Using Outlook 0
S Save in folder other than Sent when replying with Quick Steps Using Outlook 5
R Missing Quick Steps and Rules Using Outlook 0
A Quick Steps in Tasks view Using Outlook 7
J quick quesiton about outlook search Using Outlook 3
iwshim Skype tool bar in quick access ribon Using Outlook 1
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
L Quick step to fill custom field Outlook VBA and Custom Forms 1
adaminaus Quick question if i may Using Outlook 4
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
L Outlook Data Files command not working in the quick access bar Using Outlook 1
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
B quick help with "changed by" field in a shared mailbox?? Using Outlook 3
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
S Quick Search will not work due to itemizing Using Outlook 1
E Blank Print Preview when access via the Quick Access toolbar Using Outlook 3
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
K Quick Print shows wrong date on Occurrences Using Outlook 1
I Office 2010 Quick Steps Using Outlook 10
T Quick Access Toolbar Using Outlook 3
S Quick access toolbar in inspector window Outlook VBA and Custom Forms 3
V Parts of Outlook UI transparent Using Outlook 2
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
