Saving Incoming & Outgoing Outlook 2010 Email Locally with IMAP
Juliansdad
I want to set up an IMAP account with my existing email account on Outlook 2010. Will you please tell me the sequence of steps to take in order to set it up so that I can save my incoming and outgoing email locally?
IMAP is a server-based account so you will have a copy of your mailbox in outlook and changes sync up to the server. If you want to save messages locally, you need to either drag them to a local pst file or use POP3 protocol instead.
Outlook 2010 can be configured to save sent mail in the local pst file - file, account settings, double click on the account, More Settings - sent tab.
S Automate saving of attachments on new incoming emails Outlook VBA and Custom Forms 3
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
CWM550 Saving Data: Don't check certain folders Using Outlook 2
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
B Saving items under a folder Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
T Saving all email to file folder in Windows Using Outlook 2
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Kevin H Remotely saving emails Using Outlook 1
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
D Remove extension while saving attachments Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
S Not saving attachments in the Sent Folder Using Outlook 2
D Saving outlook emails in html and attachments Using Outlook 4
W Default Saving a message as text Using Outlook 2
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
B How to choose which contacts folder to use when saving contacts? Using Outlook 1
