Rules and Alerts not sending emails to "outside Network" emails
rdaughdril
I receive emergency notifications from a state agency.
I have a rule/alert set up to redistribute to emails in my outlook server and some “outside” server agencies.
The rule works fine for all the outlook servers but does nothing for the outside agencies email.
Is this a server security issue?
I can copy the email I have in the rule to the a forward email and it works fine, so I know the email is correct.
Any suggestions.
Exchange has an option to block mail forwarded to an outside address. You need to speak to the admin. If you are the admin, you need to check the settings on Exchange transport or create a contact for the address in the GAL. (Addresses in the GAL are considered internal, so forwarding works.)
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
W Fwd Outlook incomming messages to usb port after Rules and alerts applied Using Outlook 0
J Outlook 2013 - Rules and Alerts for POP3/IMAP Accounts Using Outlook 1
J Outlook - rules and Alerts Using Outlook 1
M Rules & Alerts not appearing in the File Tab (outlook 2010) Using Outlook 1
J Outlook - rules and Alerts - from group Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
A Manipulating Rules and Alerts in VBA? Outlook VBA and Custom Forms 4
R How to simplify rules Using Outlook 2
J Recover server side rules from OST/PST without access to the server Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
B Setting rules Using Outlook 1
A rules not working Using Outlook 2
M Rules and autoreply Using Outlook 1
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
L Office 365 cloud based rules Using Outlook 1
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
R When rules lose track of "specified folder" Using Outlook 6
I Outlook 2013 Rules - (client only) Using Outlook.com accounts in Outlook 1
A rules (flags) not working Using Outlook 7
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
R When rules are working but invisible and unmanageable Using Outlook 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
D Outlook Rules Using Outlook 1
Diane Poremsky Autoaccept a Meeting Request using Rules Using Outlook 2
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
