outlook reminders dont come to front :/
danx55
hi guys,
this is hacking me off now - why oh why dont outlook reminders come to the foreground all the time? :(
it means things are easily missed and is a right pain in the *rse!
anyone figured a way round it?
thanks
dan
Annoying as heck, isn't it? At this time there is not a fix or good solution, sorry. One group is working on an addin that displays the reminders similar to the blue new message alert but its not ready for release yet.
hi Diane,
that sounds very interesting :)
thanks for the info
cheers
dan
I’m late to almost every meeting I have – this is very annoying!
I read about solution using VB – but I think there should be an official fix – when is MS listening to its customers? When the left???
Ueli
hi Diane,
thanks for the info
cheers
dan
No fix yet... have you seen this article? http://www.slipstick.com/outlook/2010/outlook-2010-reminders-focus/ - there are 3 tools which may help. Reminder Alerts was written specifically for this problem - or use DeskPins to pin it on top (although having it always on top could lead you to ignore it... )
If you use multiple monitors the problem may be worse as outlook is not 100% multiple monitor friendly - it's usually best if outlook and the reminder window is on monitor 1.
A Outlook Reminders not populating for certain events Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 4
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
D Outlook for Android - Dismiss Reminders? Using Outlook 0
P Outlook 2013 reminders firing late, in batches Using Outlook 0
D Reminders in Outlook shared calendar Using Outlook 2
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
P open reminders missing after copying outlook pst file Using Outlook 2
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
W Midnight bug - Outlook Today & reminders Using Outlook 5
H Calendar entry reminders in Outlook.com Using Outlook.com accounts in Outlook 11
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
M suddenly cannot set outlook 2007 contact reminders Using Outlook 2
J Reminders dismissed on one computer re-appear on Outlook on second computer Using Outlook 1
S No Pop Up Reminders in Outlook 2013 Using Outlook 1
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
M Outlook 2007 Calendar Reminders Using Outlook 1
B [outlook-users] Re: Why have I gotten to many "reminders" for birthdays that "occurred" on Jan. 1??? Using Outlook 3
S Reminders and Due Dates in Outlook 2010 Using Outlook 6
D Email Reminders show up only when in Outlook with Windows 7 - way to fix? Using Outlook 1
C Outlook Reminders for a Shared Calendar Using Outlook 9
A stop outlook reminders generated through BCM BCM (Business Contact Manager) 3
A Outlook can't remember outlook.com, Exchange password. Using Outlook 0
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 8
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
