Exchange Outlook Issues
w1cked
Ok, I deleted a user from our exchange server because the profile was corrupt. I recreated the user under the same name. I gave them the same email address as that is what their business card says. The user can send emails fine, but every one I try to send to them bounces back undeliverable. I've found if I click a message they sent to me and hit reply, they can receive the message fine. Anyway to fix this or any idea why it is occurring?
You are using the autocomplete cache to send to them? The cache holds the old address. When that entry comes up, delete it.
If you are selecting it from the address book, the OAB may not be updated with the new address yet. You can use the Send & Receive > Update offline addresses to update it or wait up to 24 hours.
Thank you for the response. I figured that out after my post. So already fixed. Thanks for the quick response though :D
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
A Outlook can't remember outlook.com, Exchange password. Using Outlook 6
C How to fix outlook continuing to prompt fo an Exchange password Using Outlook 0
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
Z New minimum Outlook for Windows version requirements for Microsoft 365/Exchange Online Using Outlook.com accounts in Outlook 27
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
I outlook 2016 manual exchange config Using Outlook 0
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
PMR0001 Mydomain Outlook.com and Exchange post EAS Using Outlook 1
R Outlook 2016 - How to change password in MS Exchange email client Using Outlook 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
T Outlook 2013 Outlook.com to Office 365 Exchange: When? Using Outlook.com accounts in Outlook 3
D Outlook Notes and Exchange Sync Using Outlook 7
W Outlook.com -> Exchange Migration Using Outlook.com accounts in Outlook 2
D Outlook Add-on for Exchange Spam Management? Exchange Server Administration 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 Using Outlook 0
Diane Poremsky Outlook 2016 & Exchange 2007: Not supported Using Outlook 0
Ascar_CT Outlook.com transition to Exchange Server on the back-end Using Outlook.com accounts in Outlook 0
D Looking to move away from exchange to outlook.com Using Outlook 4
L what is safe size for pst of Outlook 2013 via Office 365 exchange? Using Outlook 1
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
neobite Maximum number of Exchange accounts in an Outlook profile Using Outlook 4
S Exchange server 2013 / Outlook 2013 Exchange Server Administration 3
J Outlook 2013 - Exchange 2007 manage distribution group Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
B Configure Outlook so Exchange uses cached mode but new items are by default saved to Outlook.com Using Outlook 1
