The From field difference in OL 2003 to 2010
TAVatPCU
We are testing and getting ready to move from Outlook 2003 to 2010. We noticed in the 'Folder List' and the 'From' field on messages that our names are now displayed as '[EMAIL="'mmouse@company.org"]mmouse@company.org'[/EMAIL] in 2010 verses 'Mouse, Minnie' in 2003.
If possilbe is there a place to set this back to the 2003 style? And where does it pull from?
Just trying to be ready with an answer for the ultimate question. Thanks very much.
There is a convoluted way to change it in the folder list - but you need to add the account from control panel and make the change before you open outlook. I decided it was too much effort for me. :) You can't change it once outlook creates the data files.
You can change the display name above the To field on new messages - in account settings, double click on the account then More Settings. Change the account name.
A Outlook 365 Delete entries in title field, address book Using Outlook 0
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
S Combination Field (Date Format) Outlook VBA and Custom Forms 0
J images on note field display fraction of size Using Outlook 5
C Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
V Checking for empty field Outlook VBA and Custom Forms 2
A new labeled phone field Using Outlook 4
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
N Exporting IM Address field Using Outlook 2
J How to restore field no longer visible in field chooser? Using Outlook 1
R What's supposed to appear when just clicking into the search field? Using Outlook 7
A Missing context menu on Location field Using Outlook 2
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
C Import Outlook 2016 contacts into to: field Using Outlook 1
T Source of Outlook 2016 Address field dropdown "Other Suggestions" Using Outlook 3
M Sudden change in From field - now very short Using Outlook 4
