Outlook replacement options - contact journal activities lost
Ah...so I have to go to contacts and find that contact specifically and then highlight the client (but not open it) and tene run the macro. Any way to get the macro to work from the contact info dialog box which is where I am used to obtaining a listing of historical emails?
Thanks for the help...at least I have something that works.
Kay
Assuming you are opening a contact by double clicking on an email address in the address fields of a message, changing the Set ocontact line to
Set oContact = GetCurrentItem()
and using the getcurrentitem function at the end of this article, http://www.slipstick.com/developer/outlook-vba-work-with-open-item-or-select-item/, you can run it from the inbox.
Or you could grab the sender's address - that would only find mail from that address, not from the contact's 3 addresses.
Having recently upgraded to 2013, I have to say I'm astounded by how much they changed it for the worse. The Activities tab was crucial to my business and I can't see any reason to have removed it. Outlook is quickly becoming simply a mail/phone/calendar app rather than a full information management tool. I tried to install the macro but could not make it work. And I consider is a very sad state of affairs that they put us in that position while leaving fields for "mileage" in there. Like anyone tracks their mileage in Outlook!
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
T Outlook replacement form region using a "parent" Outlook VBA and Custom Forms 1
A Outlook can't remember outlook.com, Exchange password. Using Outlook 0
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 8
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
A Outlook 2019 folder counter Using Outlook 0
A Relocate Search Bar in Outlook Using Outlook 2
L Opening People Outlook 2021 Using Outlook 2
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
