Deleting Custom Fields
srmsrm
I have a custom form in Outlook 2010. I have a custom field, but I cannot delete it. The delete button is disabled. Any suggestions on how to delete the field?
Shawn
srmsrm
Thank you very much. However, how do I delete the field? I'm not big programmer so not sure how to delete the field if the delete button is disabled and then how do I change the version number?
Thank you for your time.
Forum Admin
You need to open the form using Design this form - in Outlook 2010, go to File, Options, Customize ribbon and add a check to Developer (on the right side) so you can access the commands easier. You'll be able ot delete the field from there. Is there a reason why you want to delete it? It's probably easier to leave it there and ignore it.
srmsrm
Thank you all for your help. I was able to delete the field. I appreciate all the feedback.
