Serious Outlook help needed!!!
chrisf695
First post to this forum and looking for some expert help on this...
My Situation has to do with my boss...
He has outlook 2007,
12GB PST file,
its mildly corrupted(needs scanpst twice a week),
using POP,
has over 400 folders,
over 3GBs of emails in his inbox from 2010 to present.
gets his email on this ipad and cell phone using IMAP also.
Ive been telling him for months that he needs to maintain his email and of course he doesnt... He is now freaking out on me to fix his situation and its really stressing me out. Whats the best plan of action on something like this??
Thought about getting outlook 2010 and starting a new pst file and importing his folders and archiving his older mail in his inbox and ad that to the 2010 account...
Upgrading is not going to be a magic fix.
Are you running scanpst because you think it needs fixed or because Outlook says it needs it? Scanpst will always find something wrong - it's not a sign of a failing pst file.
If he doesn't need to access the older mail frequently, he should archive it. I'd probably archive it by year. Should be ok to leave 2011 and 2012 in the current pst - at the end of this year, archive 2011. Only open the older archives in the profile if he needs to access mail in them - outlook will run faster/smoother this way.
Once you archive the older mail, if outlook does not complain about the pst being corrupt, keep it - otherwise export it to a new pst and swap them out.
See AutoArchiving by Received Date in Outlook - Slipstick Systems for how to archive by received date.
S Serious PROBLEM!!!! Exchange Server Administration 3
A Outlook can't remember outlook.com, Exchange password. Using Outlook 0
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 8
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
A Outlook 2019 folder counter Using Outlook 0
A Relocate Search Bar in Outlook Using Outlook 2
L Opening People Outlook 2021 Using Outlook 2
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
U Outlook 2021 not showing contact cards in Searches Using Outlook 1
