And in addition, when I open up the contact from the shortcut inside the calendar event, which shows the specific contact in the folder it is from, if I add a macro the same type of macro to it in the Quick Access Toolbar, the macro does not work. And if I go to Develper, and then Macros, and pick one of the macros that the same type of macro, it does not start up either when I click on run the macro from that area.
Now if I had added the macro the to contact after opening up the contact from the shortcut in the calendar appointment, and as I said the macro does not work, when I open up the contact directly from the folder, the macro that I added also works.
So for some reason, these macros do not work from the contact when I open the contact from the shortcut in the calendar event.
