Outlook macro help
supert8ch
having issues at this part of the macro.
I wish to have the format show up as
MMDDYYYY HHMM Name Subject.msg
(name would be who sent email as showing in Outlook)
I end up getting:
MMDDYYYYY HHMM AMD Subject.msg
Here is the code I found that gets me almost to the right setup.
Sub SaveAsnewname()
'this macro saves selected emails to a chosen location with the format
' "DATE TIME INITIALS message subject", and includes the attachments in it as it is in .msg format Dim Mitem As Outlook.MailItem
Dim prompt As String
Dim name As String
Dim Nname As String
Dim Exp As Outlook.Explorer
Dim sln As Outlook.Selection
Set Exp = Application.ActiveExplorer
Set sln = Exp.Selection
If sln.Count = 0 Then
MsgBox "No objects selected."
myPath = BrowseForFolder("\\")
Set Mitem = Outlook.ActiveExplorer.Selection.Item(1)
Nname = InputBox("Please enter subject or leave blank for email subject line(S) Please note THIS WILL GIVE ALL SELECTED EMAILS THE SAME TITLE, therefore they will only be distinguishable by date and time.")
For Each Mitem In sln
If Mitem.Class = olMail Then
If Nname = "" Then
name = Mitem.subject
name = Nname
(removed code)
If myPath = False Then
MsgBox "No directory chosen !", vbExclamation
Mitem.SaveAs myPath & "\" & Format(Mitem.ReceivedTime, "MMDDYYYY HHMM") & " AmB " & name & ".msg", olMSG
MsgBox "You have not saved"
Next Mitem
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
'Function To Browse for a user selected folder.
'If the "OpenAt" path is provided, open the browser at that directory
'NOTE: If invalid, it will open at the Desktop level
Dim ShellApp As Object
'Create a file browser window at the default folder
Set ShellApp = CreateObject("Shell.Application"). _
BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
'Set the folder to that selected. (On error in case cancelled)
BrowseForFolder = ShellApp.self.path
On Error GoTo 0
'Destroy the Shell Application
Set ShellApp = Nothing
'Check for invalid or non-entries and send to the Invalid error
'handler if found
'Valid selections can begin L: (where L is a letter) or
'\\ (as in \\servername\sharename. All others are invalid
Select Case Mid(BrowseForFolder, 2, 1)
Case Is = ":"
If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
Case Is = "\"
If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
Case Else
GoTo Invalid
Exit Function
Invalid:
'If it was determined that the selection was invalid, set to False
BrowseForFolder = False
End Function
I get AMB:
03132013 1024 AmB TEST.msg
Because the code says so:
mItem.SaveAs myPath & "\" & Format(mItem.ReceivedTime, "MMDDYYYY HHMM") & " AmB " & name & ".msg", olMSG
My test message subject had an invalid filename character (/) and it failed with that - I have code that strips invalid characters if you need it. Save Messages as *.DOC File Type - Slipstick Systems - it's at a the bottom of the code
I tweaked to it to strip invalid characters - added this code - use mItem.Sender to get the sender's name.
Dim sName As String
sName = Format(mItem.ReceivedTime, "MMDDYYYY HHMM") & " " & mItem.Sender & " " & name
ReplaceCharsForFileName sName, "_"
mItem.SaveAs myPath & "\" & sName & ".msg", olMSG
and the ReplaceCharsForFileName macro from the link I posted.
supert8ch
Dim sName As String
I had to strip some code as it would not let me post some where around 4000 characters. Here is the code I stripped, it belongs at the (removed code )
' Cleanse illegal characters from subject... :/|*?<>" etc or sharepoint wont have it!
name = Replace(name, "<", "(")
name = Replace(name, ">", ")")
name = Replace(name, "&", "n")
name = Replace(name, "%", "pct")
name = Replace(name, """", "'")
name = Replace(name, "´", "'")
name = Replace(name, "`", "'")
name = Replace(name, "{", "(")
name = Replace(name, "[", "(")
name = Replace(name, "]", ")")
name = Replace(name, "}", ")")
name = Replace(name, " ", "_")
name = Replace(name, "..", "_")
name = Replace(name, ".", "_")
name = Replace(name, "__", "_")
name = Replace(name, ": ", "_")
name = Replace(name, ":", "_")
name = Replace(name, "/", "_")
name = Replace(name, "\", "_")
name = Replace(name, "*", "_")
name = Replace(name, "?", "_")
name = Replace(name, """", "_")
name = Replace(name, "|", "_")
Thank you for your input will try it out later this afternoon.
Ah - so that is what was cut out of the code.
The code below goes right after the last of the replace names - and the bolded part is what you need to replace or edit. I replaced it with "_" & mItem.Sender & "_" for this format:
03132013_1530_Ben_Smith_RE_Follow_up_from_call.msg
mItem.SaveAs myPath & "\" & Format(mItem.ReceivedTime, "YYYY-MM-DD HHMM") & "AmB " & name & ".msg", olMSG
One more thing - you have these 3 removing blanks but 2 have 2 spaces, so spaces don't get removed from mitem.subject.
supert8ch
Not sure if its the version I am running but it does not like this line:
name = Format(mItem.ReceivedTime, "MMDDYYYY HHMM") & " " & mItem.Sender & " " & name
And states:
Run time error '438'
Object doesn't support this property or method.
maybe the mItem.Sender is suppose to be something else. Will try changing it to something else tonight when I get home. Thank you for the help on this. I am new to macros and VB so this helps me in the right direction.
Use sendername with Outlook 2003, not sender. I forgot to look at your version.
ETA: sendername will work on all versions.
supert8ch
Well that was the issue. It works great. Now I have to play with it and see if I can get it to work on email directories. I have couple hundred with thousands of emails to output to file.
Thank you for your time on this.
