Animated Smileys for Outlook 2013
vze2mp9g
Outlook 2013 32 bit
This was one thing I used to use with Outlook 2003 & 2007, Emoticons, and I really miss it! There was a company (I forget the name) that had a very BIG data base of these emoticons/smiles, but then M$ changed something in it's e-mail editor, which didn't allow then to be used any more. Does anyone know of such a thing for Outlook 2013? I'm not talking a program here and there, but a data base where you can pick and choose, especially the animated ones. Grant you, when you send a non html e-mail to someone, there wouldn't be any emoticons/smiles in the message. GMail as them, and it was cute, even Facebook (which I cannot verify) has them. I would really appreciate it if someone can point me in the right direction. I did google it, but it only shows small programs here and there.
Thank You. :)
Yes, that was it. I had a subscription to them. When I looked on google, I found another place that is advertising that they have animated emoticons, the name of the company is Scorpio Software, and their program is called Handy Animated Emoticons and their web site is: Scorpio Software - Author of Handy Animated Emoticons, E-mail Talker, Block Websites Buddy, Remove Toolbar Buddy, Remove about:blank Buddy and other software I do not know if they are compatible with Outlook 2013, but they claim it works on all mail programs including Mozilla Firefox browser. Does this sound to good to be true?
It looks like it displays the icons in a format you can copy and paste into email. It won't run on my computer, so that is just a guess. If it runs on yours, it should work.
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 8
J Outlook VBA to send from Non-default Account & Data Files Outlook VBA and Custom Forms 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Outlook is categorizing emails incorrectly Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
A Outlook can't remember outlook.com, Exchange password. Using Outlook 3
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 8
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
A Outlook 2019 folder counter Using Outlook 0
A Relocate Search Bar in Outlook Using Outlook 2
L Opening People Outlook 2021 Using Outlook 2
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Is it possible to have a reminder in Outlook 2021 for every 90 days Using Outlook 3
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
