item send not tigering.
densetax2
Outlook 2007
Item = MailItem
If Item.To = "abc@abc.com" Then
prompt$ = "Are you sure you want to send this message?"
If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Check before Sending") = vbNo Then
Cancel = True
densetax2
Outlook 2007
Tried that as well. but nothing happened. is it i am doing wrong. I created - Thisoutlooksession > insert > module > added the code and saved.
Do you have macro security set to low? Tools, Trust center, macro security to check.
Any addins? Some mentioned today that an addin was keeping their macros from working and when they disabled the addin, macros worked. (They were able to re-enable the addin and all is well now.)
