VBScript copy contacts and remove duplicates
fourthgen
We have this phone system in place that links into our local contacts in Outlook.
So what I am trying to do is create a VBscript to run automatically on startup, to copy all the contacts that are stored in the public folders to the local contacts and remove any duplicates, according to date modified if possible.
Unfortunatley I am not too sure where to begin with this, does anyone know an easy way of doing this? or be able to supply me with some script to be able to customise to our needs?
Thank you in advance
this is one place to start - its for calendar but is easy to change.
Copy new appointments to another calendar using VBA - Slipstick Systems
rather than using itemadd, you'll call the macro from the startup menu.
copycontactsmacro
You can either use if statements to filter or a restrict statement - i would probably set one of the user values to mark duplicates and skip them in the future.
if user1 <> "copied to personal contacts" then
' do whatever to check for matching name or email address
' then copy and mark as copied
else
next
D Security patch seems to kill vbscript on Enterprise Level Outlook VBA and Custom Forms 4
R VBScript Commands Outlook VBA and Custom Forms 2
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
R VBScript Sendmail not selecting correct 'from' address Outlook VBA and Custom Forms 3
B Recommended Outlook & VBScript Books? Outlook VBA and Custom Forms 3
K VBScript Outlook, add attachment Outlook VBA and Custom Forms 1
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
E VBScript to replace module? Using Outlook 3
F VBScript to add pre defined text Using Outlook 5
D Custom form and VBScript Using Outlook 5
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
Y Creating a Task with VBScript Outlook VBA and Custom Forms 14
N VBScript does not run in Outlook 2003 Outlook VBA and Custom Forms 4
C Copy from one Profile to another Using Outlook 0
