PRF with OverwriteProfile=Append Is overwriting other settings
hkelley
Outlook 2013 64 bit
Background/Objective - use a PRF to change only the Exchange "HomeServer" property. We are setting up a CAS array and want to stop using the actual hostnames.
Issue:
The PRF file below will change the HomeServer property but it seems to be overwriting other profile settings - particularly the cache mode setting. I only want to change the HomeServer property and leave everything else untouched. My Outlook client is 2013 64-bit.
Do I have a setting wrong here or do I not understand how "OverwriteProfile=Append" is meant to behave?
; Section 1 - Profile Defaults
[General]
Custom=1
ProfileName=Default Outlook Profile
DefaultProfile=Yes
ModifyDefaultProfileIfPresent=TRUE
BackupProfile=FALSE
; Section 2 - Services in Profile
[Service List]
ServiceExchange=Microsoft Exchange Server
; Section 4 - Default values for each service.
[ServiceExchange]
OverwriteExistingService=Yes
HomeServer=cas01.xyz.net
; Section 6 - Mapping for profile properties
[Microsoft Exchange Server]
ServiceName=MSEMS
HomeServer=PT_STRING8,0x6608
Hallo,
we have the same problem with Outlook 2003 and Exchange 2010.
But it seems the to be the PRF file overwriting all other profile settings.
Any help?
Thx a lot.
That is weird, it shouldn't have changed - you can't deploy a PRF to change most settings, cache mode and other options are changed using a reg file or group policy. That is how you'll need to fix it too.
What settings were changed besides cached mode?
