HELP! MSN to Outlook
Mmerhoff
Right now, I'm using MSN Premium for my email and have stored a "ton" of emails on the MSN server. Unfortunately, MSN is currently messed up and I'm seriously thinking about "dropping it" in favor of another provider. I have a licensed copy of Outlook 2010 that I purchased to record contact information. However, I've never used it for my email. I'm now concerned about somehow moving my email from MSN to Outlook so that I at least have the emails in case I decided to drop MSN. I'm not totally ignorant but am NOT a tech! Can someone tell me if this can be done? If yes, please give me step by baby step directions on how I do it. I know that I need to review and delete a ton of "old" emails but some of this email is "history" that I will need to be able to access,search, etc. etc. etc. Help will be greatly appreciated!!!! Mmerhoff
AFAIK, the premium accounts use the same servers as Hotmail/Outlook.com, so you can use POP3 or the Outlook Connector.
See online services for instructions to configure either account type.
POP3 is inbox-only, so if you use folders, you'll need to use the connector. If you want a backup and use the connector, export it to a pst file after everything is downloaded. Once everything is synced, you can switch to POP3 if you want.
Nufc1980 Outlook "Please treat this as private label" auto added to some emails - Help. Using Outlook 3
CWM550 Outlook 365 HELP! Calendar Craziness! Using Outlook 5
