Marketing and Project Management field are not displaying
wallisellener
Outlook 2013 64 bit
Hello
We have the following issue with BCM: after selecting the Marketing or the Project Management Page there is nothing being displayed.
The output remains white and no error message is appearing.
Is this issue known?
Cheers
W
wallisellener
Outlook 2013 64 bit
After doing some research I found a workaround (not sure if it's a permanent solution):
- in Outlook go to Options -> Add-Ins -> BCM for Outlook -> Go to
- here in COM-Add-Ins menu: the BCM for Outlook and BCM Loader Program for Outlook were unselected
- select both boxes and restart Outlook
In the next couple of days we will see if the settings are saved.
Cheers
W
Interesting. I'm surprised that anything BCM related was loaded with those unchecked. If they don't stay checked then something is causing Outlook is disable the addin. There is a way to tell outlook to always load them, but it's better to at least know why its disabling them before forcing them to load.
