HTTPS Connection to Exchange 2007 is continuously dropped
  • Thread starter denism
  • Start date Views 5,281
denism
Hi. We have the problem with our Exchange 2007, when connecting using
RPC over HTTPS - if the mail box has significantly large items
(3-5Mbs) the Outlook starts continuously loosing the connection going
through states: Connected - Trying to connect... - Disconnected -
Trying to connect... - Connected
This happens only in the case we're using RPC over HTTPS and happens
both outside of the network and inside the network with at least
100Mbit connection.
If we're connected from outside through VPN and using the standard RPC
instead of RPC over HTTPS everything is working just great even on
slow connections.
Did anyone experienced the same issue?
jamestechman
I have never heard of this. When this occurs have you tried ctrl +
right clicking your outlook icon on bottom right tray, connection
status. Are you getting high latency then normal or not connecting at
all? Are you using NLB? If so; have you tried individually testing one
node at a time?
James Chong (MVP)
MCITP | EMA; MCSE | M+, S+,
Security+, Project+, ITIL
> 100Mbit connection.
> slow connections.
denism
> node at a time?
> James Chong (MVP)
> > 100Mbit connection.
> > slow connections.
> > Did anyone experienced the same issue?-
Hi James,
Yes, I tried to Ctrl+Right Click the "Connection status" - it shows a
combo box with different options: "Download Full Items" is always
enabled, because we're usually working with 100Mbit link to network.
I didn't completely understand the question "Are you getting high
latency then normal or not connecting at all?". When I'm working in
LAN, I'm getting "Connected", "Updating inbox folder: 18 Mb left",
then in some moment it drops, shows "Trying to connect to Exchange",
then shows "Connected", then once again "Trying to connect to
Exchange", the back "Connected", then may stabilize and start
downloading item, then dropping once again...
Is the NLB is a "Network load balancing"? If so - we don't use it. And
what Node do you refer to?
Denis
denism
> > node at a time?
> > James Chong (MVP)
> > > 100Mbit connection.
> > > slow connections.
> Hi James,
> Thanks,
> Denis-
More on that - I ran the Outlook.exe /rpcdiag and it shows me a lot of
failure.
The string looks like:
Server name: rpc.server.com
Type: Mail
Interface: Realtek RTL8139
Conn: HTTPS
Status: Established
Req/Fail: 2354/392
Avg Resp: 8
jamestechman
Can you run your rpc\http test here and see if it comes back with a
clean bill of health if not post any errors.
https://www.testexchangeconnectivity.com/
James Chong (MVP)
> > > node at a time?
> > > James Chong (MVP)
> > > > 100Mbit connection.
> > > > slow connections.
> > Hi James,
> > Thanks,
> > Denis-
> failure.
> Type: Mail
> Conn: HTTPS
> Status: Established
> Req/Fail: 2354/392
> Avg Resp: 8-
Andy David {MVP}
On Wed, 8 Apr 2009 00:48:55 -0700 (PDT), denism <dmazourick@gmail.com>
> 100Mbit connection.
> slow connections.
hmmm,wonder if this an issue with IIS. Google
"MaxConcurrentRequestsPerCPU" and "Outlook Anywhere". You should see
some hits.
denism
> James Chong (MVP)
> > > > node at a time?
> > > > James Chong (MVP)
> > > > > 100Mbit connection.
> > > > > slow connections.
> > > Hi James,
> > > Thanks,
> > > Denis-
> > failure.
> > Type: Mail
> > Conn: HTTPS
> > Status: Established
> > Req/Fail: 2354/392
> > Avg Resp: 8-
The only error posted is a validity of the certificate. And yes, it is
not an SSL granted by Verisign (or something like that), but I have
the root certificate zone trusted on my computer and it shouldn't be a
problem as I know.
denism
On Apr 8, 8:49 pm, Andy David {MVP}
<ada...@pleasekeepinngcheesebucket.com> wrote:
> On Wed, 8 Apr 2009 00:48:55 -0700 (PDT), denism <dmazour...@gmail.com
> >100Mbit connection.
> >slow connections.
> some hits.
Me and one more person is people who tries to connect. We're very
small. At the time of test I was a single person that tried to connect
to Exchange over HTTPS (and that was a LAN)
jamestechman
Try adding this reg hack and see if it makes a difference.
Error messages when you try to connect Outlook 2007 to Exchange
Server: "The action cannot be completed" or "Your Microsoft Exchange
Server is unavailable" or "Cannot start Microsoft Office Outlook"
http://support.microsoft.com/kb/913843
James Chong (MVP)
> > >100Mbit connection.
> > >slow connections.
> > some hits.
> to Exchange over HTTPS (and that was a LAN)-
denism
> Server is unavailable" or "Cannot start Microsoft Office Outlook"http://support.microsoft.com/kb/913843
> James Chong (MVP)
> > > >(3-5Mbs) the Outlook starts continuously loosing theconnectiongoing
> > > >100Mbitconnection.
> > > >slow connections.
> > > some hits.
That didn't help at all.
I agree that this is probably not client, but server (e.g. IIS) issue.
As I posted above in the log, we're getting some Autodiscover issues -
probably this is the case... What I see is that Outlook tries to POST
to /Autodiscover/Autodiscover.xml..
Or, probably the easiest way is to disable and then re-enable the
Outlook Anywhere....
jamestechman
You did that reg hack on the client not the server right?
> > James Chong (MVP)
> > > > >100Mbitconnection.
> > > > >If we're connected from outside through VPN and using the standardRPC
> > > > >slow connections.
> > > > some hits.
> Outlook Anywhere....-
denism
> > > James Chong (MVP)
> > > > > On Wed, 8 Apr 2009 00:48:55 -0700 (PDT), denism <dmazour...@gmail..com
> > > > > >100Mbitconnection.
> > > > > >slow connections.
> > > > > some hits.
Sure :)
denism
> > > > James Chong (MVP)
> > > > > > >100Mbitconnection.
> > > > > > >slow connections.
> > > > > > some hits.
> > > I agree that this is probably not client, but server (e.g. IIS) issue..
> Sure :)-
So, this issue continues bothering me... I got new laptop and
installed all the fresh software and have exactly same issue with
Outlook 2007 connecting Exchange 2007.
I'm wondering if opening the support incident will help us.
K
KB
> > > > > Error messages when you try to connect Outlook2007toExchange
> > > > > Server: "The action cannot be completed" or "Your MicrosoftExchange
> > > > > James Chong (MVP)
> > > > > > > wrote:
> > > > > > > >Hi. We have the problem with ourExchange2007, when connecting using
> > > > > > > >RPC overHTTPS- if the mail box has significantly large items
> > > > > > > >(3-5Mbs) the Outlook startscontinuouslyloosing theconnectiongoing
> > > > > > > >This happens only in the case we're using RPC overHTTPSand happens
> > > > > > > >100Mbitconnection.
> > > > > > > >instead of RPC overHTTPSeverything is working just great even on
> > > > > > > >slow connections.
> > > > > > > some hits.
> > > > > > toExchangeoverHTTPS(and that was a LAN)-
> > Sure :)-
> Outlook2007connectingExchange2007.
Hi, I have had the same issue and found it to be related to the
communication between IIS and Exchange. I you still haven't solved it,
try to look at your third party security apps. For instance antivirus,
firewall etc - you could try disable (or uninstall those apps for a
test).
Best regards,
Kristian Bjørklund, MCP
http://www.datalogik.dk
