Outlook 2007 Delete and Paste Between Fields
LMS
I have a number of new fields the contact form which are date fields and combobox text fields. Is there simple macro that deletes what's in that field of the contact, and pastes it to a different field?
So in that code, just change the Custom1 to the field name I want it to come to and then change User1 to the name of the field it comes from? Correct?
Thanks so much as I have a lot to do.....and this code works perfectly re between two commboboxes....but when I run the code, it asks what folder to be in, and I have to answer that my selected a folder from the list that shows up....so is there a way I don't have to select a folder as that takes a lot more time as I have many many folders:
Here is the code and its great ...thanks so much:
Sub ConvertFields()
Dim objApp As Application
Dim objNS As NameSpace
Dim objFolder As MAPIFolder
Dim objItems As Items
Dim objItem As Object
Set objApp = CreateObject("Outlook.Application")
Set objNS = objApp.GetNamespace("MAPI")
Set objFolder = objNS.PickFolder
If Not objFolder Is Nothing Then
Set objItems = objFolder.Items
For Each objItem In objItems
' make sure you have a Contact item
If objItem.Class = olContact Then
' convert to your published custom form
objItem.MessageClass = "IPM.Contact.Contact Form 1"
' copy data to your custom fields
objItem.UserProperties("Status 1:") = objItem.UserProperties("First Status:")
objItem.UserProperties("First Status:") = ""
objItem.Save
Set objItems = Nothing
Set objItem = Nothing
Set objFolder = Nothing
Set objNS = Nothing
Set objApp = Nothing
that line shows up as an error and it says object requried.....any thing as this is important
oh, i forgot to change Ns to objNs when i copied it from another code sample because i was too lazy to type it. :)
Thanks again...I changed it but it did not do it....it did nothing....
Secondly, the code that works after picking the folder, does not work for a date field situation...
So two things to finish.......don't want to have to pick a folder....and make the date fields work with this........and by the way as to the code that works so far, I can select more than one contact and its does form each contact in the selected contact
It's a base macro - you need to edit it to make it work for your needs.
This line tells it to apply to all items in the folder:
if you want to use it on the selected item only, you need to change it to use GetCurrentItem() or Selection.Item(1), same as you use in any of your other macros.
For the date, try using UserProperties("field").value
I fixed the name of the date field and it works.....but the line objItem.UserProperties("DateFieldName") = "" is an error and when I took it out, the date moves over but the initial field is not empty
And I don't understand what to change so I don't have to select the folder......as when I select a list of contacts it works when I select the folder from the folder list that shows....
So I want to delete the date field that it comes from and I don't understand what to change re the code for not having to select a folder
I created a small new date field in the contact form at the bottom, and leave it as None....meaning, not date...and just made in the macro that the date field that adds to the other field, then that first date field is set up as it equals the other little field I created, and it shows up as empty....
So just need to know how to now have to select a folder...and please give me the details not just the concept...thanks so much
And specifically what do I change so it just works eithe selected contacts not all contacts in a folder?
I changed the full code per the concepts you gave me, and it works with either one, and I found thru your area the Function to add. But it does not work for a list of contacts I select, only one that is selecte or open...so is there something to add or change that does it for a list that I select?
And here is what is working so far:
Sub ConvertStatustoStatus1test()
objItem.Save
Set objNS = Nothing
I read in one of your areas the code that changes a field for the selected contacts. I think you called it Bulk. So how can we use that for the concepts of changing a field from another field and the field it is coming from is "".
Thats what I read but don't know how to change for this change to the selected contacts:
L Outlook 2007 Delete Email Addresses Using Outlook 19
S can't delete duplicate account under Outlook 2007 (Win 7) Using Outlook 16
L How can I delete stationery from Actions, New Mail Message Using in outlook 2007? Using Outlook 6
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
