Pick Folder Substitute-----IMP AND URGENT
ankit
i have outlook installed on my machine that has 4 mailbox in it( one is my default inbox, other three are my work related exchange server mailboxes)
i have created a tool, that creates an excel file of emails marked with a specific category for a specified date range
MY PROBLEM:-
to choose mailbox from which email is required
Temp solution:- i have used pick folder , which works absolutely fine
:cool:
[Set objNameSpace = objAppl.GetNamespace("MAPI")
Set ContactsFolder = objNameSpace.PickFolder]
Work Around:- i want to hard code it to second account's inbox folder, which i am unable to do
:mad:
can anyone help me with this
Regards,
GUPTA Ankit
Are they actual accounts or secondary mailboxes (managed mailboxes)?
If an actual account, check out the second macro: Macro using a specific account. The code will check all of the accounts in the list and choose the one that matches the address string.
The macro at Send email from another address using VBA may work for a managed mailbox.
Good day!
Can you suggest an alternate to the pickfolder function? I have two email accounts at work but the pickfolder function opens my default mailbox. while I need it to open the other mailbox, which my colleague and I share when working. Any suggestions will be appreciated.
farrissf Category list to pick from Outlook VBA and Custom Forms 4
L However, before you place an order, you want to pick out whether or not you want the to Using Outlook 0
T Pick-a-Meeting in Outlook 365 Using Outlook 2
Diane Poremsky How to Create a Pick-a-Meeting Request Using Outlook 0
E Automatically pick up Recipient's Name on the Body of the Email Message Using Outlook 1
B Llimit the number of people accepting one of the "pick a date" meeting Using Outlook 1
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
Q Email Address from Pick List Outlook VBA and Custom Forms 4
S Pick from list to use in a field Outlook VBA and Custom Forms 2
M Search message, then (1) Jump to folder & (2) Select message that you searched for Outlook VBA and Custom Forms 7
A Outlook 2019 folder counter Using Outlook 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
V Folder Properties - Gmail account can't switch Using Outlook 5
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
G Adding a contact to a specific folder Using Outlook 0
Rupert Dragwater Duplicate email in Folder Using Outlook 7
L "Insert Pictures" Button-Wrong Folder Using Outlook 5
CWM550 Outlook 365 Hey Diane! MS 365 Biz Standard and "Potential Spam" addressed to others coming to my JUNK folder? Using Outlook 2
A manual rule sends mail to wrong folder Using Outlook 5
D This folder up to date vs all folders up to date Using Outlook 1
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 3
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
S Folder Pane Colour Categories Using Outlook 6
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 2
