Outlook Macro for flagging messages
llravlin
I'm hoping someone can help me. I have the following code in ThisOutlookSession
prompt$ = "Do you want to flag this message for followup?"
If Item.Importance = olImportanceHigh Then
With Item
> MarkAsTask MarkThisWeek
> TaskDueDate = Now + 1
> Categories = "FOLLOW UP"
> UnRead = False
> Save
If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Add flag?") = vbYes Then
With Item
' sets a due date in 2 days
> TaskDueDate = Now + 2
> UnRead = False
> Save
It works beautifully. Now I want to add one more if statement dependant on who it is sent to. I added this...
If Item.SendTo = "email address" Then
With Item
> MarkAsTask MarkNextWeek
> TaskDueDate = Now + 10
> Categories = "NB FOLLOW UP"
> UnRead = False
> Save
Nothing happens when I send the email...the popup box doesn't even come up. What am I missing/doing wrong?
Any help is appreciated.
Laura​
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Macro to attach a file in a shared Outlook draft folder Outlook VBA and Custom Forms 2
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
L Outlook 2007 - Macro Re Search Using Outlook 16
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A newb outlook macro help Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
S Macro in an excel for outlook. Outlook VBA and Custom Forms 2
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
P Outlook Macro sends information to Excel Using Outlook 1
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
