why won't the automatic send/receive work
Jeremy Reese
I have the auto set for 1 minute but no matter what i set it will not show new emails unless i go into a specific folder or manually click on send/receive
I should qualify that. The inbox receives new emails the sub-folders will not.
Is it pop3 or an imap account? It sounds like imap behavior. You should keep the autocheck time above 5 minutes, i usually recommend 8 - 10, because Outlook may not be finished checking for new mail before the next check starts as it is limited in how many threads it can open to a server at one time. If you have a lot of folders and new mail, it might need more time to check each folder.
You can check your send and receive settings to see if all of the folders are being checked or just the inbox. Use Ctrl+Alt+S to open the dialog or look on the Send & Receive ribbon > send/receive groups > configure send/receive.
Thanks Diane.
You are right its an IMAP I ticked the wrong box. I have changed the refresh time and will monitor what happens. Its just that one sender is providing business leads and we are judged against others they send to by our response time. I have been missing the emails as it does not show when a new email is there unless I manually send/receive.
Hope this works.
didn't work. still found an email in a folder 30 minutes after it was sent by clicking on that folder
Hope this works.
Got a smart phone you can configure to get alerts?
Or I could put you together with another guy who is having problems with mail arriving every minute.... he wants Outlook to check mail once or twice day. :)
The problem appears to be that it will not flag new emails in sub folders of Inbox. The only solution I have come up with is to stop selection a criteria for moving them to sub folders and leave them all in the inbox until I re4ad them. Its a pain as it used to work perfectly. Some coding on an upgrade has caused it not to work I suspect.
Is outlook or the server moving them? If the server, you won't see the envelope when new mail arrives in the subfolder because it doesn't pass through the inbox - but the bold indicator should work on the folder. I add the folders I use the most to the Favorites list so i can easily see if new mail arrived.
icacream New password won't update Using Outlook 2
C Why won't Title display in message list? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
M outlook won't open! Using Outlook 1
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
M other user's mailbox won't open, forms disappeared Using Outlook 42
P Outlook 2016 won't Start Using Outlook 3
Phil52 Outlook won't work Using Outlook 1
N editing drafts - won't let me save Using Outlook 12
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
Jaegel Email Hyperlinks from one source won't open Using Outlook 4
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
A iPhone Contacts in Outlook won't File As First, Last Using Outlook 0
JulieB Default data file won't change Using Outlook 6
B Restoring PST files won't work Using Outlook 1
J Outlook won't open. PST file busy. Using Outlook 3
P Outlook 2007 won't connect Using Outlook 6
S Outlook 2010 won't send on Windows 8 Using Outlook 2
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
K Macro won't consistently re-enable Outlook VBA and Custom Forms 2
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
V Custom form won't open for edit Outlook VBA and Custom Forms 3
C images won't display in email Using Outlook 2
B icloud calendar stopped syncing, won't restart Using Outlook 1
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
R Emails won't come into outlook but can send Using Outlook 0
G Why won't VBA see a copied calendar in cache mode anymore? Outlook VBA and Custom Forms 20
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
Z Outlook opens minimized, won't maximize Using Outlook 2
J Email won't send Automatically in Outlook 2010 Using Outlook 3
G Outlook 2013 won't download images Using Outlook 6
O Calender first day Sunday won't stay Using Outlook 3
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
C email sending window won't go away even after email has sent Exchange Server Administration 2
