Custom Fields & Forms
LarryH
Outlook 2013 32 bit
Exchange Server 2013
I am using outlook 2013 and want to create custom fields and custom forms. Having troubles with some fields that show None and do not seem to edit. Can't get the custom form to be my default. How can i get contacts created on a standard form to show and be used in the new custom form w/fields?
LarryH
Outlook 2013 32 bit
Thanks. I think I have the custom fields and form creation process completed successfully. Now the issue is mapping a csv. file into the form/fields that I created. they do not show in the import mapping wizard.
Forum Admin
Right, you can't map them. You'll need to use VBA to add the values ot the fields or a 3rd party utility like contactgenie.
