How to copy attachments from a Public Folder in VBA
Mark Graves
Exchange Server 2010
I am trying to copy attachments that are on a Public Folder (non-default folder) using VBA. I have seen plenty of examples of this from your Inbox or a folder under it, but not from a Public Folder. I know the path and name of the Public Folder that i am looking to get the attachments from. Any help will be greatly appreciated. Thank you
Mark Graves
Here is the code i use to access a folder under my Inbox called "Temp":
Dim olFolder As Outlook.Folder
Set olFolder = Application.GetNamespace("MAPI").GetDefaultFolder(olFolderInbox)
Set olFolder = olFolder.Folders("Temp")
Mark Graves
Thank you much Diane, I will get it a try. I also found in the help system of outlook "How to: Obtain a Folder Object from a Folder Path". I have been able to get it to work. I passed the folder Location to a function and the function sets my Public Folder object and i able to go thru all of the emails with attachments and copy them to a folder on my computer. Only the ones that are pertaining to my Location.
Thanks again.
