Simple code to look for a specific line
Frankmil
Hi Diane!
I tried to look for this simple code in your forum but I didn't find it.
I always receive mail with label and without label(thank to you,I know how to extract data with label ones) , I just want to extract the line before the last one . For exemple , my mail is:
Xxxx
Thank you very much
Jone smith
Industry corp and cie
What is the vba outlook 2010 to use for looking (and copy) the one before last line (here it's jone smith).
Thank you for your help
Frank
I don't know if you could count lines and get the next to last one, but unless a line containing 'thank' always leads the line you want, its going to be tough to do. (I assume the last line will vary.) Actually, if you can count lines, you would also need to test for content, because blank lines at the end would throw it off.
If the preceding line will always have thank in some form, try something like "thank(.*)\n(.*)\n" and pick up the second (.*)
Yes, the preceding line will always have thanks line.
But how I pick up the second (.*)?
Regards
GregS Simple calendar sharing doesn't work Using Outlook 6
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
L Simple Macro Using Outlook 1
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
F I want simple syncing between my 3 PCs and Android devices. Using Outlook 1
H Too simple I would think but.. Using Outlook 1
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
R Simple Sharing of Outlook Profile Using Outlook 1
Rupert Dragwater Is there a genuine simple way to move Eudora address to Outlook 2010 Using Outlook 2
R BCM with MS Office Accounting... Simple question BCM (Business Contact Manager) 0
P Simple Marketing Campaign Question BCM (Business Contact Manager) 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
V simple move to personal folder Outlook VBA and Custom Forms 1
T Simple MAPI send and Outlook COM addin Outlook VBA and Custom Forms 3
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
