Filtering a view based on a custom field
Randy Redekopp
We use Outlook 2013 (and 2010) connected to Exchange accounts on Office 365 enterprise plan.
I have create a custom field that shows the delay time between when an email was sent (or at least when it is shows as being sent), and when it was received. I created it in the user’s inbox and also created it in their deleted items folder.
Formula: int(([Received]-[Sent])*1440)
This part works great and I have created a search folder which includes both the Inbox and Deleted Items folders (without subs). I can see and choose my custom field just fine on the view screen.
I created a new view for that search folder and filtered it based on email received in the last 7 days. I want to further filter that list down to only show email where the Delay is > 1 minute. BUT… I cannot reference my custom field for the filter screen. The “User Defined fields in <folder>” is blank for filtering, grouping, and for query builder. I am familiar with SQL so thought I might be able to use that but don’t have a data dictionary or any examples to get started there.
Is what I am trying to do possible? If so, how would you suggest I tackle it?
-Randy-
It's because its a formula field. You can use VBA to make the calculations, which will be sortable, groupable, and filterable. See http://www.slipstick.com/outlook/email/sort-messages-sender-domain/
I created a custom field using the first macro on the page - replaced two lines with the following:
         strDomain = (objMail.ReceivedTime - objMail.SentOn) *  1440
         Set objProp = objMail.UserProperties.Add("DelayTime", olInteger, True)
Those lines will work in any of the other macros on the page.
