How will I delete messages permanently?
Estelle
Hi, I am quite new and inexperienced with Outlook. I have 2007 version, directed mails from a hosting server to my Outlook, having a number of different e-mail addresses linked to the same web hosting domain. What I have noticed, when I click on X, to delete the message, it remains there and crossed, paler in grey shade, like in the file I have just uploaded. I mark them and move to the Deleted Items folder. None of these X-ed ones go to the deleted items folder automatically though. Getting back to the previous sentence, when the transferred group of previously deleted items appear in the deleted items folder, and when deleting them there, they disappear, but no change have happened in the original mail accounts, all of these accounts, except of one, where the deleted emails disappear on the first click on X. I do not understand this. I have been looking for guidance how to delete the items permanently, but it just does not seem working. Any ideas?
That is how it works when you use an imap account - when you delete mail, it gets marked for deletion and is purged when you change folders or manually purge. You can use a view to hide messages marked for deletion.
Thank you. I already have it sorted, the purging maneuver was needed which I did not know about.
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 3
O How to delete duplicate RSS messages? Using Outlook 6
F delete unsended messages Using Outlook 1
T How to remove "automatically delete messages form this sender"? Using Outlook 1
F Automatically delete previous messages in a conversation Using Outlook 2
H How to delete Messages in ascending order - Outlook 2010 Using Outlook 4
A Delete messages on server Outlook VBA and Custom Forms 1
D Delete Outlook emails from MS server Using Outlook 12
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
G Automatically delete email when a condition is met Outlook VBA and Custom Forms 1
M Shift Delete doesn't delete email from server Using Outlook 3
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
O How to delete a forum post? Using Outlook 4
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
O Delete duplicate emails - subscription notifications Using Outlook 5
L Email Read and Delete Outlook VBA and Custom Forms 4
H Delete Calendar Entries in Using Outlook 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Outlook 2016 cannot delete, email showing in root Exchange Server Administration 5
