Loads of junk in second email needs fixing
lotsbg
I have changed computers where I use outlook and imported an outlook data file which has all the old calanders, contacts etc. However, this contains my junk folder, and my new email gets all the junk, as it would seem the junk filter only applies to the data file, not my email address. I cant seem to copy the junk folder across, yet I get email normally though the jlowe@sportpunter.com address, just with all the junk (300+ emails a day!). If someone can help that would be great.
Please see attached file for picture.
Outook's junk filter needs the full message body to filter and imap is slow about bringing down the bodies. Does you mailbox online have any spam filters? Getting rid of the spam before outlook touches it is always better.
R Outlook loads when the computer boots Using Outlook 1
J 2007 Form Design loads 2003 Form Outlook VBA and Custom Forms 12
J BCM no longer loads SQLServer BCM (Business Contact Manager) 2
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
J Why are my Junk options shown as slashed off Using Outlook 6
Jay Freedman Outlook forgets "not junk" marking Using Outlook 0
J How to Block junk/spam domain Using Outlook 0
CWM550 Outlook 365 Hey Diane! MS 365 Biz Standard and "Potential Spam" addressed to others coming to my JUNK folder? Using Outlook 2
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
J how to stop junk emails from *.onmicrosoft.com ? Using Outlook 2
I Junk Mail and PersonMetadata Using Outlook 2
F Outlook 2016 Junk E-Mails Using Outlook 5
J Junk mail doesn't work Using Outlook 3
T New Account Shows No Junk Mail Folfer Using Outlook 0
T Probem with junk mail folder in new account in Outlook Using Outlook 0
C Why can junk mail be from one’s own email address? Using Outlook 7
M junk mail folder Using Outlook 2
Diane Poremsky Junk Mail Filtering in Outlook Using Outlook 0
K Emails stuck in 'Junk' folder Using Outlook 0
David Rahrer Change default Junk E-Mail folder Using Outlook 6
S Outlook.com - Junk files Using Outlook.com accounts in Outlook 1
R Not junk email Using Outlook 3
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
G filtering email with missing TLD to Junk Outlook VBA and Custom Forms 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
R Outlook 2007 junk mail Using Outlook 4
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
C Outlook 2013 Junk Mail Filters Using Outlook 0
L My junk email folder has disappeared - Using Outlook 0
Commodore Junk Mail filtering and IMAP Using Outlook 3
D Junk Mail filter Using Outlook 1
V Macro to view Junk Email folder Using Outlook 4
J Junk email Exchange Server Administration 1
V Emails going to Junk folder Using Outlook 2
A Junk mail Using Outlook 4
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
