Auto retrieve wont work
outlook 2013 will not auto retrieve even with time changed to 1 minute. Can someone help me out
  • outlook timing
    Votes: 0 0.0%
  • outlook timing is not functioning
    Votes: 0 0.0%
  • Total voters
    0
Frank Pita
Outlook 2013 64 bit
i am using outlook 2013 64 bit and cannot get outlook to do an auto retieve.. it is only checking on manual
send/recieve. Can someone please help me out
Do you get any error messages? How frequently are you checking for new messages? Ctrl+Alt+S to open the Send / Receive dialog to check the frequency and settings.
Have you tried deleting the SRS file for your profile and letting Outlook recreate it? Try or paste
%appdata%\microsoft\outlook in the address bar of windows explorer and press enter to find it.
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
F Auto changing email subject line in bulk Using Outlook 2
