applying a rule to the message body only
moks
Hello
I'm using outlook 2010 & want to create a rule to categorize any message have the word (offer) with attachments.
following are the settings :
the problem is the actions are taken for every message received in the conversation based on the existence of these words in previous messages
i want only to categorize the message where its body contain these words and any upcoming replies after this message shouldn't be categorized unless it satisfies the rule conditions.
if the replies in the thread include the word, it would be categorized... but normal behavior when manually categorizing is all new messages will be categorized if you categorize the conversation instead of the individual message - - it sounds like the rule is treating the message as a conversation. I'll see if i can repro - it's a bug in my opinion.
Unfortunately, I don't know of a way to change the behavior.
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
G Applying rules to email generated from MS Access by VBA Using Outlook 6
CWM550 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
