Outlook.com EAS Issue
jf2go
Outlook 2013 32 bit
I joined OutlookForums hoping that someone may be able to help me with this issue. For some reason, my perfectly working Outlook 2013 Exchange ActiveSync connection to my hotmail account stopped working last week. Outlook shows "Connected", then "Waiting for Server Response", then disconnects. No emails, calendars, contacts get downloaded/synced whatsoever. I can successfully send from the account though. There are no errors in the Sync Issues folder. I have removed and re-added the account, created a new profile with only the Outlook.com account, changed the EAS server from blu406-m.hotmail.com to m.hotmail.com (as well as a few others), disabled Anti-Virus, etc. A different computer (my laptop) is running Outlook 2010, and it is not syncing either. I get Sync errors on that PC (0x80004005 and 0x8004102A). I can login to the Web Outlook.com, and everything is fine. I can setup the account as IMAP or POP, and that works fine. It is just EAS that is not working.
I went to the AnswerDesk and let them remotely login to my PC (cringe!!!!), and they went through pretty much the same troubleshoot steps that I did, with no success. They then recommended that I contact the Office support team. I created a case with that team, and they remotely logged into my PC and did the same troubleshooting as the AnswerDesk. They couldn't fix it and escalated the case to Level 2 who created a new case. The Level 2 tech called and said that the issue is with the Outlook.com severs, and that I needed to work with the AnswerDesk, as they had direct access to the EAS/Mail servers. I went *back* to the AnswerDesk, and they said that there was nothing that they could do, and I needed to contact Microsoft Pro Support. I called that number, and it seemed to go back to the same Office team. The new tech (I should have gotten her name), remotely logged into my PC and went through essentially the same troubleshooting steps for EAS, then created an IMAP account and said "there you are, it's working now. Is there anything else that I can do for you today". I told her in the beginning of the session that I had created an IMAP account as a temporary workaround for mail, and I knew that IMAP and POP worked. I told her that I need to get EAS working. She seemed to not pay attention to that, and indicate that this was all she could do, then quickly and abruptly ended the call.
I don't know if anyone else is having (or has had) the same issue and was able to get this resolved. I do think that it is possibly a setting or something on the Outlook.com side, but I don't know who to call or email to get help. For now, I can get my email using IMAP, but unfortunately can't do any calendar or contact sync.
I'm guessing it's related to the updates last week. Are you using two step authentication?
Try removing the stored credential for this account from Control Panel > User > Credential Manager > Windows Credentials
Thank you for the reply Diane!
I have not (intentionally)setup two-step verification in my Microsoft account. I have noticed recently that when I sign in to my account, there is an extra step where it texts a code to my cell phone, that I need to input before I can get into my account for maintenance. Is that what you are referring to? My account does still offer "Set up two-step verification", and doesn't show that it is turned on.
Regarding the stored credential, I see two things relating to my Hotmail account. They are both under "Generic Credentials", there is nothing but names of the PCs/Servers that I login to under "Windows Credentials".
> One entry just has my Hotmail email address and Modified: 8/15/2014
> The other entry has WindowsLive (token):name=<My-Hotmail-Email-Address> and Modified: 8/15/2014
Should I remove one or both of these?
Still no luck. I don't have two-step verification turned on, because I don't have the entry for App Passwords listed in my account. From your link, once I complete the setup for two-step, App Passwords appears. So as not to further complicate things, I won't complete the setup for two-step right now.
I deleted the Generic Credentials for my hotmail account, but Outlook is still not syncing with EAS. I also created a new Generic Credential for my hotmail account, but that didn't help either. I modeled the entry from another hotmail account that *is* working in Outlook 2013 with EAS. I had forgotten to mention earlier, one hotmail account is syncing fine, my other (primary) hotmail account is not.
Don't create credentials in the credential manager - outlook will create them when you try to log into the account.
I'd probably remove the account from outlook and add it back.
Yep, I have done that a couple of times, and even created a brand new profile without only the Outlook.com EAS account. Unfortunately, it never syncs - just connects, sits there for 5 minutes "Waiting for Server Response", and disconnects.
PMR0001 Mydomain Outlook.com and Exchange post EAS Using Outlook 1
Diane Poremsky Configuring SmartPhones to use EAS to Outlook.com Using Outlook 0
Commodore Is Outlook.com EAS in Outlook 2013 "non-renamable"? Using Outlook.com accounts in Outlook 2
P Using IMAP and EAS with outlook.com account Using Outlook.com accounts in Outlook 9
J Local Outlook 2013 folder and message changes not synced with EAS to Outlook.com Using Outlook.com accounts in Outlook 7
S Outlook.com set up as EAS in Outlook 2013 – Emails can take up to 25 minutes to arrive Using Outlook.com accounts in Outlook 9
S Drafts in Outlook 2013/Outlook.com with EAS & IMAP Using Outlook.com accounts in Outlook 5
M Outlook 2013 EAS, 3 imap accounts. Meeting invites not synced to outlook.com Using Outlook.com accounts in Outlook 1
A Outlook can't remember outlook.com, Exchange password. Using Outlook 0
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
HarvMan Outlook.com Account Using Outlook 3
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
D Outlook.com premium finally dying... what do I do with my domain? Using Outlook.com accounts in Outlook 3
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
T Missing Folder in Outlook.com Using Outlook 3
dbjdbj Is it only me having a fun time with Outlook.com "beta" ? Using Outlook 3
I New Outlook.com Using Outlook 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
M Can't send email in outlook.com Using Outlook 9
T BitDefender reporting outlook.com as 'insecure' Using Outlook 6
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
C Syncing on outlook.com Using Outlook 4
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
B Outlook.com People Limits Using Outlook.com accounts in Outlook 11
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
