Incoming mail not downloading
Annabe
Outlook 2013 32 bit
I am using Outlook 13 and all worked fine. I downloaded AVG and could no longer download from the mail server any incoming mail. Also get message that I don't have appropriate permission to perform action if I try to delete read messages from my inbox. How do I download my mail?
Does it work in Safe mode? To open Outlook in Safe mode: Close Outlook then hold Ctrl as you click on the Outlook icon. You'll get a message asking if you want to start in Safe mode. Click Ok.
Go to File, Options, Addins and uncheck the AVG addin. Does that fix it?
Hi Diane. Thanks. I have started in Safe mode - no luck. Subsequently uninstall AVG. There is still a McAffee add-in. Will that cause problems? When I try to delete mail in the in-box it states that I don't have appropriate permission to perform the action. Could it be linked with my incoming mail problem? I can send mail - no problem. My incoming server is imap and then my email address.
Anything else I can try. I am really frustrated.
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
T Incoming Mail Changes Fonts Using Outlook 0
R VBA to manage incoming mail Outlook VBA and Custom Forms 2
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
S Outlook incoming mail & color blindness Using Outlook 2
E Outlook cannot connect to your incoming (POP3) e-mail server/Cannot send mess. Using Outlook 0
D size of font on incoming e-mail Using Outlook 1
N Providing a reference to incoming mail in outlook 2007 BCM (Business Contact Manager) 2
M how to save incoming mail in TRUE csv format Outlook VBA and Custom Forms 1
H can i automatically create new contact from specifc incoming mail BCM (Business Contact Manager) 2
P How do i add the date to subject header of incoming mail? Outlook VBA and Custom Forms 13
J Auto processing of incoming mail Outlook VBA and Custom Forms 1
B A rule to file incoming mail in a public folder Outlook VBA and Custom Forms 2
S Distributing incoming mail among users Outlook VBA and Custom Forms 3
G Date Stamp in SUBJECT BOX of Outgoing/Incoming Mail Outlook VBA and Custom Forms 11
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
T Search for incoming e-mails for a specified time range Using Outlook 1
I Capture incoming emails Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
P Use VBA to alert if new incoming email fits criteria Outlook VBA and Custom Forms 0
A Processing Incoming E-mails with Macros Using Outlook 0
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
