Copy email from preview pane with headers
jlibs804
My first post but I've been reading this forum and slipstick for a few weeks now. Through that and other sites I've come up with this VBA which allows me to copy an email directly from the preview window with headers.
Sub copyall()
Dim m As MailItem
Dim cb As Object
Set m = ActiveExplorer().Selection.Item(1)
tmp = "c:\temp\mytest.txt"   'any filename as long as it does not overwrite some wanted file
Set m = m.Forward
m.SaveAs tmp, 0
m.Close olDiscard
Open tmp For Input As 1
mymsg = Input(LOF(1), #1)
Close 1
Kill tmp
Set cb = CreateObject("clipbrd.clipboard")
cb.Clear
cb.SetText CStr(mymsg)
My problem is that when I paste the email the first 12 lines are not needed which include a Subject line, an Include line, then a few blank lines and then 7 lines for my signature. I'm manually removing these lines but am trying to customize the VBA above to do that for me. Or come up with another approach. I seem to be struggling either way. Can anyone put me in the right direction?
Thanks for the reply Diane. I would have two questions regarding that approach; 1.) Would that still give me the headers so that my copy essentially looks like this (below). 2.) How would I go about copying form the original message?
Sent: Tuesday, December 02, 2014 4:16 PM
To: Davis, John
Cc:
Subject: RE: ABC Proposal #Z6372 - Install - Remote Training (8 estimated hours) to Include: Website
Let’s close out the ticket and I will make sure we just bill the 7 hours.  We can quote again later if or
when they decide to move forward.
Kelly Smith
  Administrative Services Manager
  ABC, Inc.
12345 Gerburry Rd. Suite 100
Austin  TX 64428
P: (555) 860-2559 ext. 311
F: (555) 754-4460
ksmith@abc.com
When i commented out the forward line in your code, it was formatted just like your sample.
Sent:    Wednesday, August 20, 2014 9:17 AM
To:    name
Subject:    Re: subject
message
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
L Copy email body fields to excel Using Outlook 0
D How to copy yahoo email folders to hard drive Using Outlook 2
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
S VBA to identify a specific email and copy the attachment from it to the network Outlook VBA and Custom Forms 4
L Outlook 2007 Copy Email Address in To Field Using Outlook 11
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
A Macro to copy email body to new email Outlook VBA and Custom Forms 5
P Copy email address from outlook 2013/2010 Using Outlook 1
M Copy "To" Address Value from a Newly Created Email to the "To" Address Field of Custom Form Using Outlook 4
O Copy email content and paste into new Word Document using a different font Using Outlook 1
R Macro to copy email address Using Outlook 6
A Copying cc email addresses to Excel - does not copy the <joe.bloggs@isp.com> Using Outlook 1
R how to copy a list of email contacts and paste them only as names (not names + email address) Using Outlook 12
B Mark copy of sent email as read - VBA? Outlook VBA and Custom Forms 3
R Sending a copy of an incoming email to a network folder Outlook VBA and Custom Forms 1
K Copy Entire Email Content - Paste into new Task Outlook VBA and Custom Forms 2
C Copy email to different folder, works in 2003 but not 2007 Outlook VBA and Custom Forms 3
S Using copy paste to grab email addresses from the TO: address fiel Using Outlook 14
C Copy from one Profile to another Using Outlook 0
